[GRASSLIST:1819] Re: grass build error: compilation error in r.in.gdal
Kirk R. Wythers
kwythers at umn.edu
Wed Nov 19 10:28:09 EST 2003
On Nov 19, 2003, at 2:19 AM, Glynn Clements wrote:
> OK. I believe that this is because you need some additional switches
> when linking against C++ code (most of GDAL is C++).
> It may suffice to replace "gcc" with "g++" in the link command. Either
> by running the above command manually, but substituting "g++" for
> "gcc", or by editing src/raster/r.in.gdal/Gmakefile, changing $(CC) to
> "g++".
> Typically, there would be a standard library (or even a simple object
> file) which defines the above symbols, and using g++ as the linker
> will use that library (or object file) automatically.
> E.g. on Linux, C++ programs use libstdc++. Linking with "g++"
> automatically implies "-lstdc++"; if you link with "gcc", you have to
> explicitly add "-lstdc++" to the link command.
> Note: this issue doesn't normally arise for shared libraries, as they
> typically include dependency information, so the linker will add any
> dependent libraries automatically.
I'll be damned... that did it Glynn. I have not used it yet but the
compile finished without any errors. Just for the sake of the continued
pursuit of knowledge, why was this an issue on my machine and not for
others (who appeared... superficially at least, to be building on the
same/similar hardware and os (OSX 10.3.1, gcc 3.3 from xtools)?
Thank you
> I suppose that the gdal-config script should really deal with this.
> Glynn Clements <glynn.clements at virgin.net>
Kirk R. Wythers tel: 612.625.2261
Dept. of Forest Resources fax: 612.625.5212
University of Minnesota email: kwythers at umn.edu
