[GRASSLIST:1845] Re: Mac OS X - new GRASS 5.7cvs binaries
Markus Neteler neteler at itc.it
Thu Nov 20 11:07:40 EST 2003
On Thu, Nov 20, 2003 at 10:44:00AM -0500, Christopher Fonnesbeck wrote:
> It prints "powerpc"
> I will try your suggested fix. Thanks.
I have updated the package on my site:
http://mpa.itc.it/markus/grass57/macosx/
Hopefully that's it for a while...
M.
> C.
> On Nov 20, 2003, at 10:29 AM, Markus Neteler wrote:
> > On Thu, Nov 20, 2003 at 10:05:18AM -0500, Christopher Fonnesbeck wrote:
> >> I installed this binary (on a machine that has 5.0.2 working fine) and
> >> got the following error  on startup:
> >> dyld: /usr/local/grass57-19_11_2003/etc/lock can't open library:
> >> /grass57exp/dist.powerpc-apple-darwin6.8/lib/libgrass_gis.dylib  (No
> >> such file or directory, errno = 2)
> >> /usr/local/grass57-19_11_2003/etc/Init.sh: line 160:  4747 Trace/BPT
> >> trap          "$ETC/lock" "$lockfile" $$
> >> Unable to properly access /Users/chris/.gislock57
> >> Any ideas?
> > Yes. We have to catch all HOSTTYPE values a Mac could have.
> > So far "macintosh" and "powermac" are implemented.
> > What does
> >  echo  $HOSTTYPE
> > print?
> > For a quick solution edit
> > search for "powermac"  and add your HOSTTYPE there.
> > Then it will work.
> > Reason: Mac OSX uses DYLD_LIBRARY_PATH instead of LD_LIBRARY_PATH.
> > At time your HOSTTYPE is not detected properly in the script.
> > So please let us know your HOSTTYPE.
> > Cheers
> >  Markus
> >> Chris
> >> On Nov 20, 2003, at 4:41 AM, Markus Neteler wrote:
> >>> Yesterday I have compiled new GRASS 5.7 binaries for
> >>> Mac OSX. Now using shared libraries - the download
> >>> package size is only 8 MB:
> >>> Cheers
> >>> Markus Neteler     <neteler at itc.it>       http://mpa.itc.it
> >>> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> >>> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> >>> Via Sommarive, 18        -       38050 Povo (Trento), Italy
> >> Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
> >> Georgia Cooperative Fish & Wildlife Research Unit, University of
> >> Georgia
> Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
