[GRASSLIST:1852] Re: r.in.gdal not found
Glynn Clements
glynn.clements at virgin.net
Thu Nov 20 15:37:36 EST 2003
Kirk R. Wythers wrote:
> Now that grass is built and installed (with gdal) without any errors, I
> have a couple of user questions.
> First issue... when I try and import a non-georefrenced file with the
> command:
> GRASS:~ > r.in.gdal
> in=~/projects/wrf/map_imagery/typestand2325/legend1.tif out=legend1
> I get the message:
> bash: r.in.gdal: command not found
This indicates that r.in.gdal isn't installed. Try running "make" and
"make install" again.
Glynn Clements <glynn.clements at virgin.net>
