[GRASSLIST:1864] Re: error with d.m in grass57
    Markus Neteler
    neteler at itc.it
    Sat Nov 22 13:27:51 EST 2003
On Fri, Nov 21, 2003 at 01:03:32PM +0100, hamdi ines wrote:
> hello,
> i want to use the graphic for grass 5.7, I used the
> d.m command but the result is:
> >Error in startup script: ps.map: error while loading
> shared libraries: libpq.so.3: cannot open shared
> object file: No such file or directory
This indicates that either PostgreSQL is not installed or
a different version.
Markus
>     while executing
> >"exec ps.map -p"
>     (procedure "DmPrint::init" line 14)
>     invoked from within
> >"DmPrint::init"
>     (procedure "main" line 27)
>     invoked from within
> >"main"
>     (file "/home/softgrass/binnb/etc/dm/d.m.tcl" line
> 765)
> please can you help to resolv the problem.
> thank you.
> ___________________________________________________________
> Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et en français !
> Yahoo! Mail : http://fr.mail.yahoo.com
