[GRASSLIST:1877] s.in.shape error
David Kidd dmk2 at st-andrews.ac.uk
Tue Nov 25 06:07:30 EST 2003
Dear Grasslist,
I am very new to GRASS so this may be a known problem, however, I have had
no joy searching for a solution.
I wish to use s.surf.rst to interpolate a surface from my point data set
but am having trouble importing my point data from ARCGIS. I have a
shapefile with z values (attached) created in ARC CATALOGUE that when I
import with  s.in.shape -z in=/home/dave/grassdata/lgmdtann.shp  says that
there is an error in site#39 and fails to load all 148 records.
Any suggestions gratefully received
Many thanks
Dave Kidd
David M. Kidd
Research Assistant
School of Biology
Room 210, Sir Harold Mitchell Building
University of St. Andrews
St. Andrews, Fife
KY16 9TH
UK
http://www.st-and.ac.uk/~bugs/dave/dave.htm
Tel:  +44 (0)1334 463348
Fax: +44 (0)1334 463600
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20031125/3b2b2329/shapefile.zip
