[GRASSLIST:1883] RE: configuring Grass5.03 on Debian
Jim Browne
jbrowne at liu.edu
Tue Nov 25 10:36:46 EST 2003
Glynn,
The last part of the logfile states:
configure: failed program was:
#line 4793 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid and error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char deflate();
int main() {
deflate()
; return 0; }
If this is a small test program, I don't see what it does. When compiled on
its own, the compiler complains "undefined reference to deflate" and stops.
However, when I add:
#include <zlib.h>
then it only complains of "too few arguments to function 'deflate'" before it
stops. What is this testing, and how do I get around this?
Thanks,
Jim
>===== Original Message From Glynn Clements <glynn.clements at virgin.net> =====
>Jim Browne wrote:
>> I am trying to compile Grass5.03 on Debian Linux and the configure script
>> stops at :
>> checking for location of zlib library...
>> checking for deflate in -1z... no
>Examine config.log for any applicable error messages.
