[GRASSLIST:1895] Re: mysql,pg drivers for 5.7
Christopher Fonnesbeck
chris at fonnesbeck.org
Wed Nov 26 10:42:55 EST 2003
On Nov 26, 2003, at 4:17 AM, Markus Neteler wrote:
> On Tue, Nov 25, 2003 at 09:10:02AM -0500, Christopher Fonnesbeck wrote:
>> Yes, I was using Markus' binary, which based on the configure script
>> he
>> pointed me to was not compiled with either database driver. I am
>> trying
>> to compile it myself now.
> If you manage to do that (shouldn't be too difficult), could you
> publish the binaries? I would appreciate if someone could take
> over on a (ir)regular basis for MacOSX.
> Markus
> PS: The machine I was using didn't contain PG etc.
>> C.
>> On Nov 25, 2003, at 8:59 AM, David Orme wrote:
>>> Are you using the binary version provided for Mac OS X by Markus
>>> Neteler? I've downloaded the same thing and it works fine (Thanks,
>>> Markus) but has the same limited set of drivers (dbf, shp) - I've
>>> been
>>> assuming that the binary was built without postgres, mysql and odbc
>>> support in order to reduce the set of dependencies and make the
>>> binary
>>> more portable. If this isn't the case, I'd like to work out how to
>>> get
>>> pgsql and odbc too but I suspect I need to configure and build my own
>>> copy if I want a postgresql and ODBC support.
>>> David
>>> On Tuesday, November 25, 2003, at 12:12 am, Christopher Fonnesbeck
>>> wrote:
>>>> I am trying to use either mysql or postgresql to store attributes
>>>> for
>>>> a GRASS database I am building in GRASS 5.7 (since 5.0.2 does not
>>>> work reliably with postgresql). Unfortunately when I try and manage
>>>> the default settings using v.database as outlined in the tutorial,
>>>> the only drivers are dbf and shp (since when is shapefile a database
>>>> driver??). Nowhere does it say where to get the pg/mysql drivers, so
>>>> I would be most appreicative of anyone who would point me in the
>>>> right direction. It might be a good idea to include these in future
>>>> releases.
>>>> Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g
>>>> Georgia Cooperative Fish & Wildlife Research Unit, University of
>>>> Georgia
I think I have everything configured properly, however when I try and
build, I get the following errors. Any ideas? I scanned the list
archives, but did not find anything helpful:
cd OBJ.powerpc-apple-darwin7.0.0;
LD_LIBRARY_PATH=:/usr/local/src/grass57_exp_2003_11_22/dist.powerpc-
apple-darwin7.0.0/lib ./test
ERROR in read/write portable short
Written: -32768
Read : 0
Written: -12345
Read : -57
Written: 12345
Read : 57
Written: 32767
Read : -1
make[3]: *** [OBJ.powerpc-apple-darwin7.0.0/test] Error 1
make[2]: *** [subdirs] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
