[GRASSLIST:1897] Re: pie/bar chart of vect variables in 5.0.x
    Martin Wegmann
    mailinglist2_wegmann at web.de
    Wed Nov 26 11:26:19 EST 2003
Hello,
I suppose you mean library(GRASS), what you have to use when R shall run
inside GRASS.
My problem is not the interface with R, that works fine so far but the chart
option in GRASS 5.0.2.
I could in R do rast.get() for my rastermaps and display them in R and the
barchart wouldn't be a problem but R slows down significantly when trying to
handle a data frame of a few 100 000 values, therefore I would like to keep
the whole rastermap in GRASS and only transfer the values for the barchart
into GRASS and display the charts there.
Or I upgrade to 5.1. but as long as it is not meant for productiv use, I
prefer to keep 5.0.x.
cheers, Martin
On Wednesday 26 November 2003 16:05, Christopher Fonnesbeck wrote:
> The best way is to use the interface with R. See Marcus' short course
> notes for details.
> Chris
> On Nov 26, 2003, at 8:40 AM, Martin Wegmann wrote:
> > Hello,
> > I transfered data values of 66 plots from R to GRASS using sites.put()
> > and
> > plotted their values via the v.bubble command on the background of a
> > raster
> > image.
> > I wonder if a pie chart or bar chart is as well available this way.
> > I looked for d.vect.chart but that seems to be only available in >5.1.
> > Is it due to the limit of one variable/vector in 5.0.x?
> > I there a way to plot a pie/bar chart of vector values (8 variables)
> > in 5.0.2?
> > thanks in advance, cheers Martin
> Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
> Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
