[GRASSLIST:1397] Re: postgreSQL problem
    Antonio
    nightnavigator at libero.it
    Fri Oct  3 18:27:35 EDT 2003
* giovedì 02 ottobre 2003, alle 19:06, Uttam Kumar scrive:
> Hi GRASS users,
>               I have downloaded the postgreSQL-7.3.4. I unzipped it and
> then went to the same dir of the postgresql and then installed it as
> follows:
> 1.)  ./configure  --prefix=/home/grass0pre3/psql
> --bindir=/home/grass0pre3/bin --without-readline
> 2.)  gmake
> 3.)  gmake check
> 4.)  gmake install-all-headers
> 5.)  gmake distclean
> Then I wrote the following line in /etc/ldconfig
> "/home/grass0pre3/psql/lib" for the shared libraries.
> Then I created a database and initialized it
> root# mkdir /home/grass0pre3/psqldata
> root# chown grass0pre3 /home/grass0pre3/psqldata
> root# su grass0pre3
> grass0pre3$ initdb -D /home/grass0pre3/psqldata
> Lastly I started the server with
> /home/grass0pre3/bin/postmaster -i -p 5432 -D /home/grass0pre3/psqldata
> >logfile 2>&1 &
> Now when I run
> createdb abc
> and then
> g.select.pg database=abc
> I get the following error...
> Error: select Postgres:could not connect to server: Connection refused
>        Is the server running on host localhost and accepting
>        TCP/IP connections on port 5432?
> an any body tell me the problem and its related solution or have I missed
> anything during installation.
It typically seems a problem concerning postgres not accepting
connections on the 5432 socket.
I suggest a few things:
a) go and set the tcpip_socket value to 1 (not 0) in the postgresql.conf
file (do a find to see where it is or try with "whereis
postgresql.conf";
b) edit the pg_hba.conf file (should be in the same dir) and make sure
you have something like this:
local        all                                           ident
sameuser
host         all         127.0.0.1     255.0.0.0           ident
sameuser
host         all         0.0.0.0       0.0.0.0             reject
host         all        192.168.0.3   255.255.255.0       ident sameuser
in it.
It should do the game :-)
Bye
