[GRASSLIST:1405] Re: import AVHRR.
Daniel Victoria daniel_victoria at yahoo.com
Sat Oct 4 13:35:22 EDT 2003
Hi all
I'm also working with AVHRR images but I'm importing
them in a different software because when I first
started working with them, GDAL would import but would
not do the automatic georreferencing. Does GDAL do
that now?
Thanks
Daniel
--- Andrey Kiselev <dron at ak4719.spb.edu> wrote:
> On Sat, Oct 04, 2003 at 04:54:03PM +0900, Alip.Yasin
> wrote:
> > Thank you too much.
> > I tried command r.in.gdal input=A3164585.L4908097
> output=name, but it  said:
> > ERROR4: 'A3164585.L4908097' not recognised as a
> supported file format.
> Looks like you have outdated GDAL. Please, run
> `gdalinfo --formats'
> command and check whether the output contains a line
> for
> `L1B: NOAA Polar Orbiter Level 1b Data Set'. If so
> and you still get an
> error when reading your dataset, you should report
> this problem
> via Bugzilla
http://bugzilla.remotesensing.org/enter_bug.cgi?product=GDAL
> Andrey V. Kiselev
> Home phone:  +7 812 5274898  ICQ# 26871517
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
