[GRASSLIST:1437] Re: import .bil DEM file (cascadia.bil)
Torge Schuemann
ts at uvic.ca
Tue Oct 7 21:36:34 EDT 2003
Hi Daniel and the others,
I tried again to import that *.bil file, as some time has gone by since my
initial attempts.
In general I have to admit that I am a newbee to GIS and my general
approach to projections etc. is very much try and error ...
I am working in a Lat/Lon location, the cascadia.bil file reflects a UTM
location - does that cause additional problems?
However, I tried to import it into both types of locations without success.
I get complaints about "bytes not match File size" regardless what I try
... (see below)
Thanks,
Torge
*** Lat/Lon location ***
GRASS:~/geodata/dem/cascadia > r.in.bin -s input=cascadia.bil
output=cascadia.grass bytes=1 north=53 south=39 east=244 west=227
Using rows=14 cols=17
Bytes do not match File size
File Size 76589370 ... Total Bytes 238
Try bytes=321804 or adjusting input parameters
*** UTM location ***
output=cascadia.grass bytes=1 north=1710340.289 south=101590.289
east=749705.938 west=-738044.062
Using rows=1608749 cols=1487749
File Size 76589370 ... Total Bytes 1117932129
Try bytes=0 or adjusting input parameters
On Tue, 7 Oct 2003 17:04:21 -0700 (PDT), Daniel Victoria
<daniel_victoria at yahoo.com> wrote:
> You should be able to import the file using r.in.bin.
> I don't have my linux box on now so I can't remember
> the command but I think you must have the header file
> with the same name as the bill file (just different
> extension .bil and .hdr)
> Also, you will have to play arounf with the bite
> swaping option. Can't remember now if the motorola
> (sun) needs bite swap on or off. Import and check the
> values, if they are off than change the biteswap.
> Acording to what you sent, the values - before
> correcting for the offset - should range from 400 to
> something in the order of 5000
> Hope to have helped
> Daniel
> --- Torge Schuemann <ts at uvic.ca> wrote:
>> Hi,
>> for quite a while I am trying to import a *.bil file
>> into GRASS 5.0.1 by
>> using various modules (r.in.bin and r.in.gdal).
>> I am not familliar with the *.bil format, but the
>> archive "cascdem.tar.gz"
>> I downloaded from
>> http://geopubs.wr.usgs.gov/open-file/of99-369/
>> includes
>> some meta data which I applied when using the import
>> modules.
>> However, so far I haven't been lucky although I
>> think I more or less tried
>> every possible combination of the parameters given
>> below.
>> As info for the data set itself: It contains a
>> 250-meter digital elevation
>> model (DEM) for Cascadia (latitude 39N - 53N,
>> longitude 116W - 133W), a
>> region that encompasses the Cascade volcanic arc,
>> the Cascadia subduction
>> zone, and the Juan de Fuca Ridge system offshore
>> Washington (USA) and
>> British Columbia (Canada).
>> Any help is appreciated, thank you all!
>> Cheers, Torge
>> Here below I copied the available information which
>> is included in the tar
>> archive.
>> ***** cascadia.blw: *****
>> 250.00000000000000
>> 0.00000000000000
>> 0.00000000000000
>> -250.00000000000000
>> -737919.06250000000000
>> 1710215.28906250000000
>> ***** cascadia.hdr: *****
>> BYTEORDER M
>> LAYOUT BIL
>> NROWS 6435
>> NCOLS 5951
>> NBANDS 1
>> NBITS 16
>> BANDROWBYTES 11902
>> TOTALROWBYTES 11902
>> BANDGAPBYTES 0
>> ***** cascadia.prj *****
>> Projection LAMBERT
>> Zunits NO
>> Units METERS
>> Spheroid CLARKE1866
>> Xshift 0.0000000000
>> Yshift 0.0000000000
>> Parameters
>> 41 30 0.000 /* 1st standard parallel
>> 50 30 0.000 /* 2nd standard parallel
>> -124 30 0.000 /* central meridian
>> 38 0 0.000 /* latitude of projection's origin
>> 0.00000 /* false easting (meters)
>> 0.00000 /* false northing (meters)
>> ***** cascadia.stx *****
>> 1 5147 14378 9371.3 2076.8
>> ***** excerpts from README.txt *****
>> This report contains a 250-meter digital elevation
>> (latitude 39N - 53N, longitude 116W - 133W), a
>> Cascade volcanic arc, the Cascadia subduction zone,
>> Ridge system. The DEM is distributed as file
>> cascdem.tar.gz (39 MB; 78MB
>> uncompressed).
>> The DEM contains elevation values in integer meters,
>> at regularly-spaced
>> points in a Lambert conformal conic projection with
>> standard parallels at
>> latitudes 41.5N and 50.5N, and a central longitude
>> of 124.5W (the
>> "Cascadia" projection.).
>> To ease data transfer for the widest possible range
>> of users, the DEM is
>> distributed as a BIL (Band Interleave by Line) file,
>> produced with the ARC
>> GRIDIMAGE command. For grids (the ARC term for a DEM
>> in the form of a
>> regular array of height values), such files are more
>> compact than ARC
>> export (.e00) files and USGS DEM-format files, and
>> are much faster to
>> create and import. They can also be read by many
>> applications other than
>> ARC. cascadia.bil is such a file of binary integers.
>> Elevations are stored
>> in cascadia.bil as unsigned positive 2-byte binary
>> integers, in Motorola
>> byte-order (default for Sun hardware), with an
>> offset of 10000. That is,
>> 203 meters is stored as 10203 meters, and values
>> less than 10000 represent
>> negative elevations. Values of 0 in cascadia.bil
>> represent no data. Values
>> are given by row, west to east, starting at the
>> north edge of the region.
>> To convert CASCADIA files to an ARC grid
>> Assemble the cascadia.* files (.bil, .blw, .hdr,
>> prj; .stx is not
>> necessary) in one directory. Make this your
>> workspace.
>> Arc: imagegrid cascadia casc1
>> Arc: grid
>> Grid: casc2 = con(casc1 <> 0, casc1 - 10000)
>> Grid: &sys cp cascadia.prj casc2/prj.adf
>> If you DESCRIBE casc2 in ARC, you should get
>> Description of Grid CASC2
>> Cell Size = 250.000 Data Type: Integer
>> Number of Rows = 6435 Number of Values = 8555
>> Number of Columns = 5951 Attribute Data
>> (bytes) = 8
>> BOUNDARY STATISTICS
>> Xmin = -738044.062 Minimum Value =
>> -4853.000rs)
>> 0.00000
>> Xmax = 749705.938 Maximum Value = 4378.000
>> Ymin = 101590.289 Mean = -628.692
>> Ymax = 1710340.289 Standard Deviation =
>> 2076.818
>> COORDINATE SYSTEM
>> DESCRIPTION
>> Projection LAMBERT
>> Zunits UNKNOWN
>> Units METERS
>> Spheroid
>> CLARKE1866
>> Parameters:
>> 41 30
>> 0.000
>> 50 30
>> 0.000
>> central meridian
>> -124 30
>> 0.00
>> 38 0
>> 0.000
>> 0.00000
>> 0.00000
> __________________________________
> Do you Yahoo!?
> The New Yahoo! Shopping - with improved product search
> http://shopping.yahoo.com
Dr. Torge Schuemann
School of Earth and Ocean Sciences (SEOS)
University of Victoria
Tel.: (250) 721-6177
Fax.: (250) 472-4620
Email: ts at uvic.ca
Web Page: http://biogeochemistry.uvic.ca
Mailing address (mail and courier):
P.O. Box 3050
E-Hut, Room 135c
School of Earth and Ocean Sciences, University of Victoria
Victoria, British Columbia, V8W 2Y2, Canada
