[GRASSLIST:1480] Re: Watershed modelling in Grass.
Massimiliano Cannata massimiliano.cannata at supsi.ch
Mon Oct 13 08:25:33 EDT 2003
Hello,
about temperature, i think that if you have only few data of temperature
s.surf.rst will not generate a real-like temperature map.
I decide to give a try with an xy polynomial fitting with a term in z......
"Antonio G. - Geotronix" wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi.
> I was reading the manual of CASC2D and found it rather interesting.
> However I noticed that it's setup is rather complicated. Has anyone
> experienced with this model for the modelling of water balance equation
> in Grass?
> Being this my first approach in watershed modelling I was thinking I
> would rather try using a more simpler approach, especially in
> consideration of the fact that I have rather scarce data, only temp. e
> rainfall of the meteo stations.
> I was thinking I would try to obtain a temp map with s.surf.rst and a
> rainfall map with the same program. Then maybe, use r.mapcalc for
> obtaining an watershed runoff map by subtracting it from the other (I
> have an infiltration map).
> Any considerations?
> Thanks
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.2 (GNU/Linux)
> iD8DBQE/io7SIRaQQEznKxURAkvhAKCvBbPyWGySwM14MAwtUuRThM7t0QCfR5Uo
> 4WuI1ks/dWUHdTo+YCSjkxE=
> =SCu7
> -----END PGP SIGNATURE-----
note: change my e-mail reference to massimiliano.cannata at supsi.ch
      because the old one will be deleted soon.
Ing.  Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata at supsi.ch
Internet: http://www.ist.supsi.ch
