[GRASSLIST:1483] Re: r.in.gdal segmentation fault!
Paul Kelly
paul-grass at stjohnspoint.co.uk
Mon Oct 13 15:24:13 EDT 2003
On Mon, 13 Oct 2003, Zbigniew Perski wrote:
> I have two computers at work and at home. At work I have installed thae
> latest gdal (from deb packages) and grass from binary flies. And when I
If you have only the binaries available another solution would be to use a
very old GDAL (it appears to be the latest versions that have the
problems). I don't know where you could obtain that from though.
However, compiling with the --with-gdal configure option is *the* way of
fixing this for now.
