[GRASSLIST:1487] Re: Bug in s.proj?
Morten Hulden
morten at ngb.se
Mon Oct 13 22:41:13 EDT 2003
On Mon, 13 Oct 2003, John Gillette wrote:
> For a second opinion, I down loaded GEOTRANS 2.2.3 for
> Windows.
> WGS84, CEA, 0,7332956.368 to WGS84, Geodetic gives
> 0d 0' 0.0004"E 87d 7' 58.1173"N
> This is .544 Meters from ArcMAP answer.
> m.proj in Grass 5.0.0 gives same answer as cs2cs.
Then all the proj tools (v.proj, r,proj, m.proj, s.proj) in grass will
have this for cea projection. Time to ask the proj list?
M.
> > [doibook:/usr/local/bin] dorme% ./cs2cs +proj=cea +lat_ts=30
> > +datum=WGS84 +to +proj=latlong +datum=WGS84
> > 0 7332956.368
> > 0dE 86d18'12.382"N 0.000
> > ArcMAP
> > 0dE 87d 7' 58.42" N
