[GRASSLIST:1097] Re: Looking for a guru...
Bill Dickinson Jr
wdickins at pop700.gsfc.nasa.gov
Wed Sep 3 08:20:30 EDT 2003
Thanks for all the replies. ;-) It sounds to me like I should have
been on this list months ago when I first started running into
problems instead of trying to - stubbornly - figure it out myself. ;-)
I had not realized that GRASS does not need a database, so obviously
my next step is to get GRASS running by itself and then potentially
add the MySQL database support later on. Everything I had read gave
the impression that you needed to have some form of database for
GRASS to run properly, the recommended one being Postgresql. That's a
little nugget of information that should be propogated better. ;-)
Thanks again. I will try GRASS by itself and see what happens.
Bill
>Bill Dickinson Jr wrote:
>> I do not have the OpenOSX CD yet, though it is on my list if I can't
>> get it running without it. I am trying to show NASA that there is an
>> alternative GIS solution to ESRI without the costs, so I am trying
>> not to spend any money on the demo I want to develop. It seems like
>> it shouldn't be that big of a deal downloading and installing
>> everything myself and for most things it hasn't been. The problem I
>> am currently stuck on is getting GRASS to talk correctly to the
>> database.
>> You mention the LOCATION and MAPSET, which happens to be the specific
>> hurdle I am currently trying to get over. GRASS is installed as is
>> MySQL as my database, but I can't get GRASS to acknowledge a LOCATION
>> and MAPSET within the MySQL folders.
>The GRASS "database" is just a directory, not an SQL database.
>To check whether GRASS is installed correctly, install one of the
>sample datasets (e.g. spearfish) in a directory of your choice. That
>directory (the one which contains the spearfish etc subdirectory)
>should be entered into the "database" field in the start-up screen.
>Glynn Clements <glynn.clements at virgin.net>
Bill Dickinson
GIS Specialist
NASA Goddard Space Flight Center
Environmental & Safety Branch, Code 250
