[GRASSLIST:1114] Newbie GRASS questions
Bill Dickinson Jr
wdickins at pop700.gsfc.nasa.gov
Thu Sep 4 12:25:26 EDT 2003
Hey there, gang:
Well, now that I have GRASS running on my OS X box and I am running
through the SEEDS tutorial, I am going to start plaguing this mailing
list with my pithy comments and observations on GRASS. ;-) Feel free
to ignore them or berate me if they are too much. I'll try not to
bombard the list with useless fluff. ;-)
The first thing I have run into is the way certain functions work
through the text or the graphical interface. When I run g.list from
the text interface I get the appropriate list of items within the
Location, but then I can't get out of the list when it is done. I get
an (END) at the bottom of the screen, but hitting Enter does not
return me to my GRASS prompt. I have to go to another terminal window
and kill the g.list process. On the other hand, the g.list function
through the GUI works fine and doesn't hang. Has anyone else run into
this problem?
In a similar vein, when I use "d.mon select=x0" through the GUI the
WISH interface hangs, though the same function works fine through the
text interface.
Someone mentioned that the GUI was pretty rough, but so far it seems
fine to me. At least that is to say that it is about what I expected
from an open-source project without the deep pockets of an ESRI to
give it a slick finish.
I believe I read somewhere that you do need a database working with
GRASS for Vector support, which seems pretty important coming form
the primarily vector world of ArcView. At some point, I am going to
have to solve the database problems I have had with GRASS on OS X, so
if anyone is already has this setup working on OS X I would love to
talk about it offline.
Bill
Bill Dickinson
GIS Specialist
NASA Goddard Space Flight Center
Environmental & Safety Branch, Code 250
