[GRASSLIST:1117] Re: s.in.ascii | general site question
Glynn Clements glynn.clements at virgin.net
Thu Sep 4 15:52:39 EDT 2003
Kevin Slover wrote:
> I am having some difficulties importing a sites file correctly... and
> maybe it is difficulty in understanding the principles behind the ascii
> file formats.
> I am attempting to import an ascii file with general form of:
> lon lat waveheight winddirection windspeed buoynumber
> (ex: -87.5 25.2 1.0 300 15 42001)
> it is tab delimmeted, and imports with no problem.  However, in trying
> to use d.site.lables, it only allows me to use attr=double, which adds
> on unnecessary zeros, making the labels worthless.
> Is the reason why I can only use doubles is that the import data
> contains no text of any sort?  Is there any way to force it to import as
>   a string?
If an attribute consists solely of digits and ".", "+" and "-" it is
treated as a double, otherwise it is treated as a string.
You may be better off just creating the internal sites file directly
rather than using s.in.ascii; the format is described in the
s.in.ascii manpage.
Glynn Clements <glynn.clements at virgin.net>
