[GRASSLIST:1118] Re: Newbie GRASS questions
Glynn Clements
glynn.clements at virgin.net
Thu Sep 4 16:09:23 EDT 2003
Bill Dickinson Jr wrote:
> Well, now that I have GRASS running on my OS X box and I am running
> through the SEEDS tutorial, I am going to start plaguing this mailing
> list with my pithy comments and observations on GRASS. ;-) Feel free
> to ignore them or berate me if they are too much. I'll try not to
> bombard the list with useless fluff. ;-)
> The first thing I have run into is the way certain functions work
> through the text or the graphical interface. When I run g.list from
> the text interface I get the appropriate list of items within the
> Location, but then I can't get out of the list when it is done. I get
> an (END) at the bottom of the screen, but hitting Enter does not
> return me to my GRASS prompt. I have to go to another terminal window
> and kill the g.list process.
Pressing "q" will probably work.
Commands which may generate a significant amount of text typically
pipe their output through a pager. The default pager is "more" if
/bin/more exists, and "less" otherwise. If your terminal (e.g. xterm)
has an adequately-sized scroll-back buffer, you might wish to skip the
use of a pager with:
For a Bourne shell:
GRASS_PAGER=cat
export GRASS_PAGER
For a C shell:
setenv GRASS_PAGER cat
> Someone mentioned that the GUI was pretty rough, but so far it seems
> fine to me. At least that is to say that it is about what I expected
> from an open-source project without the deep pockets of an ESRI to
> give it a slick finish.
It's rough in the sense that it's basically just a menu and some
automatically generated dialogs. The overall design is
command-centred, rather than the data-centred approach which "real"
GUI programs use.
For display purposes, there is also "d.dm". This seems like a better
concept overall, but it's fairly limited in what it can do at present.
> I believe I read somewhere that you do need a database working with
> GRASS for Vector support, which seems pretty important coming form
> the primarily vector world of ArcView.
This isn't the case in 5.0; it's entirely usable without an RDBMS.
OTOH, the experimental "5.1" version does make extensive use of
database functionality for vectors.
Glynn Clements <glynn.clements at virgin.net>
