[GRASSLIST:1128] Error Problem
David Fernald
fernald at ptd.net
Fri Sep 5 21:58:15 EDT 2003
Hi All,
I've been trying to use grass5.0.2 from the OpenOSX version. I
have found that a number of things need to run from the command line,
but that doesn't matter - I'm just working on updating my rusty UN*X
skills.
My short problem is:
GRASS 5.0.2 > v.in.sdts catd=RD01CATD.DDF output=tobyrd
Processing CATD module
Error: Could not open FIPS 123 input file (RD01CATD.DDF)
ERROR: Unable to process SDTS CATS file. Exiting
Mapset <PERMANENT> in Location <Monroe>
I am trying to import data USGS vector data I downloaded from the
USGS - I think these are DLG files in SDTS format. Doing exactly (I
think) the same command I have successfully imported 5 files. I went
and did something else, came back and now I get the result above. I
tried reinstalling grass5.0.2, I tried making and installing the USGS
fips123 libraries (in multiple places), and I've tried v.import from
tcltk (wish) and v.in.dlg*. Nothing seems to work. If anyone has
any sage advice, I would appreciate it.
TIA
David Fernald, Jr.
