[GRASSLIST:1138] Re: FIX: gdal/v.in.dgn support with grass 5.0.2
Keith J. Forbes
listsemail at gmx.net
Mon Sep 8 11:46:27 EDT 2003
On Monday 08 September 2003 04:37 pm, Paul Kelly wrote:
> Hello Keith
> On Mon, 8 Sep 2003, Keith J. Forbes wrote:
> > I recompiled as follows:
> > ./configure --with-postgres-includes=/usr/local/pgsql/include/
> > --with-gdal=/usr/local/share/gdal
> > --with-postgres-libs=/usr/local/pgsql/lib
> > but now think I specified gdal location incorrectly
> > I have gdal-config in /usr/local/bin/.
> > should i use
> > --with-gdal=/usr/local/bin/gdal-config or
> It should be the first one. And if /usr/local/bin is in your path you
> won't even need that, just '--with-gdal' should suffice. Just now I have
> commited to CVS a change to make the './configure --help' output clearer
> with regard to the --with-gdal option.
> Please let us know how you get on
> Paul
Paul: Thanks for the response. Tried what you suggested
(--with-gdal=/usr/local/bin/gdal-config)
and
--snip
checking if we should build directly against GDAL... yes
no
checking whether to use TIFF... yes
---snip
any idea if it will build directly against GDAL (since it said yes, and then
no???!!!!)
Thanks,
Keith
k|J|f
