[GRASSLIST:1144] Re: Grass and mapserver question
Jorge del Pozo
jorpoz at pesquera.tel.uva.es
Tue Sep 9 04:51:13 EDT 2003
Hello.
First you have to convert the vector map into a shape file:
#vector layer in SHAPE:
#v.out.shape map=soils type=area pref=soils cats=string
DATA /path_to_htmldocs/spearfish/soils
or, if you want to display a raster map:
#GRASS raster map directly from location (8bit only):
LAYER
STATUS ON
DATA "/path_to_grassdata/spearfish/PERMANENT/cellhd/soils"
END
And also be carefully with the file's permisions.
Sorry for my poor english.
Markus Neteler(neteler at itc.it)@08.09.2003 18:38:19 +0000:
> On Fri, Aug 29, 2003 at 10:09:42AM -0400, Ling-Yen Liao wrote:
> > Hi,
> > I use GRASS 5.0.2 and Mapserver 3.6.6, and I am trying to make a connection between GRASS and Mapserver. I downloaded the DEMO 1 from
> > http://grass.itc.it/start.html
> > and everything was fine except the soils map.
> > and it was ok, but after I changed 2 places:
> > shapepath "/data/grassdata/spearfish"
> > data "PERMANENT/cellhs/soils"
> > and ran mapserv, it showed
> > msDrawRaster():Image handliing error. Unrecognized or unsupported image format.
> > Is it because the data in my grass database is not 8 bit format? if so,
> > how could I fix this? Thank you...
> See at bottom of
> the new Troubleshooting entry (use r.rescale).
> Cheers
> Markus Neteler
