[GRASSLIST:1190] Re: Grass5.1
Markus Neteler
neteler at itc.it
Thu Sep 11 05:45:45 EDT 2003
On Wed, Sep 10, 2003 at 10:16:59PM +0200, Sjors wrote:
> Hi,
> I'm trying to build grass5.1 again. I've got a cvs version (5.0.3 cvs
> april 2003) and installed latest gdalGDAL 1.1.9.0, released 2003/06/27
> and PROJ.4, 4.4.7, 31 March 2003.
> Now after './configure' en 'make mix', it breaks on 'make'. Last part
> to stdout:
> make[2]: Leaving directory
> `/home/sjors/grass/grass51_exp_2003_09_06/lib/linkm'
> proj
> make[2]: Entering directory
> `/home/sjors/grass/grass51_exp_2003_09_06/lib/proj'
> make[2]: *** No rule to make target
> `/home/sjors/grass/grass51_exp_2003_09_06/dist.i686-pc-linux-gnu/etc/nad',
> needed by `default'. Stop.
> make[1]: *** [subdirs] Error 1
> make[1]: Leaving directory `/home/sjors/grass/grass51_exp_2003_09_06/lib'
> make: *** [default] Error 1
There was a fix for that a few days ago.
Run
cvs up -dP
in your GRASS 5.1 directory to get it. Then it will compile.
Markus
