[GRASSLIST:1252] Re: a problem in NVIZ
Hamish
hamish_nospam at yahoo.com
Tue Sep 16 10:14:38 EDT 2003
> I will appreciate if anyone explains reason of this problem concerning
> NVIZ.
I'm working on it..........
> (grass5.0 runs in slackware9.0)
[that's the second hit for this bug with Slackware 9.0, for anyone
keeping score. What gcc, glibc, tcl versions is that please?]
> [GRASS:~ > nviz ...]
> Nv_(panels)
> toplevel made
> child killed: segmentation violation
hmmmm.. that's in a different place to where it was breaking for me.
(Debian/Testing)
Is it a floating point or integer based map?
If it is an integer based map, try converting it to a FP with r.mapcalc,
(r.mapcalc fpmap=origmap*1.0)
and see if that works. (doubtful)
Try compiling with -DDEBUG_MSG and see if that fixes it.
(CFLAGS=-DDEBUG_MSG ./configure ...)
[that worked here, I have no idea why]
Try compiling with gcc ~2.95 if you can & see if that fixes it.
[that works here]
Which version of Tcl are you using? Does using 8.3 help?
please let me know if any of this works, or doesn't.
I've currently got my integer-map bug tracked down to this line on
src/libes/ogsf/GS2.c: (line 1445)
filename = G_fully_qualified_name(filename, mapset);
Next is to follow G_fully_qualified_name() in src/libes/gis/nme_in_mps.c.
Hopefully this leads somewhere.
You're getting past that into etc/nviz2.2/scripts/nviz2.2_script though.
tcl8.4?? Maybe try adding -lpthreads to the end of XTRA_LDFLAGS in
src.contrib/GMSL/NVIZ2.2/src/Gmakefile
and see what that does?
also of note, we have both:
/src.contrib/GMSL/NVIZ2.2/scripts/nviz2.2_script
and
/src.contrib/GMSL/NVIZ2.2/nviz2.2/scripts/nviz2.2
Which are almost the same thing. The first one is the real one.
oh, what fun,
Hamish
> /usr/local/grass5/etc/nviz2.2/scripts
> Nv_(panels)
> toplevel made
> while executing
> "exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
> /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script
> -name NVIZ >&@stdout"
> ("eval" body line 1)
> invoked from within
> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name
> NVIZ >&@stdout"
> invoked from within
> "if {$argv == ""} {
> #no arguments
> NVIZ >&@stdo..."
> (file "/usr/local/grass5/bin/nviz" line 16)
