[GRASSLIST:1267] r.in.gdal problem
Cannata, Massimiliano
massimiliano.cannata at supsi.ch
Wed Sep 17 05:21:24 EDT 2003
Hello,
I've problem running r.in.gdal command, can anyone help
me?
this is my comman line:
GRASS:~ > r.in.gdal input=/home/mcannata/PHL.gif
output=radar
Segmentation fault
GRASS:~ >
a message in /var/mail/mcannata advice me that:
GIS ERROR: Unable to initialize GDAL bridge (check libgdal
installation/LD_LIBRARY_PATH variable)
I try to reinstall r.in.gdal command:
[root at maxi r.in.gdal]# gmake5 -i
SRC = /home/mcannata/tmp/grass5.0.2/src
CMD = /home/mcannata/tmp/grass5.0.2/src/CMD
UNUSED = /home/mcannata/tmp/grass5.0.2/unused
HEADER = head.i686-pc-linux-gnu
ARCH = i686-pc-linux-gnu
GISBASE =
/home/mcannata/tmp/grass5.0.2/dist.i686-pc-linux-gnu
VERSION = 5.0.2 April 2003
/home/mcannata/tmp/grass5.0.2/src/raster/r.in.gdal
make -f OBJ.i686-pc-linux-gnu/make.rules
make:
`/home/mcannata/tmp/grass5.0.2/dist.i686-pc-linux-gnu/etc/bin/cmd/r.in.gdal'
is up to date.
make -f OBJ.i686-pc-linux-gnu/make2.rules
make: `/usr/local//grass5/etc/bin/cmd/r.in.gdal' is up to
date.
do I miss something in my configuration? How to check it?
Thanks a lot.
Eng. Massimiliano Cannata
Phd student
www.supsi.ch
