[GRASSLIST:1274] Re: r.in.gdal problem
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Wed Sep 17 08:39:55 EDT 2003
After i do:
- configure distclean
- configure (--with-gdal)
- make
- make install
now it works correctly.
Thanks
Paul Kelly wrote:
> On Wed, 17 Sep 2003, Massimiliano Cannata wrote:
> > I also check that my /etc/ld.so.conf have the /usr/local/lib in and i also run
> > /sbin/ldconfig but nothing changed.
> > Do I have to do "make distclean" and then run "./configure --with-gdal
> Give it a try. If you have GDAL installed before you compile GRASS there
> is no reason not to do that as far as I am aware. The last person who was
> going to try this never got back to the list to say how he got on and I
> tried e-mailing him but it bounced, so it would be good to get feedback.
> Is the file available somewhere we could download and test it (if possible)?
> Paul Kelly
note: change my e-mail reference to massimiliano.cannata at supsi.ch
because the old one will be deleted soon.
Ing. Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata at supsi.ch
Internet: http://www.ist.supsi.ch
