[GRASSLIST:1299] Re: command which works like "d.what.rast" command but non-interactively
Glynn Clements
glynn.clements at virgin.net
Fri Sep 19 01:25:23 EDT 2003
Hayashi Shin-ichiro wrote:
> I'm using some raster map which is DEM.
> I'm searching for GRASS command which is mentioned bellow.
> * If I give xy coordinates on raster map to command, command return
> * elevation value.
> * command works non-interactively.
> Does GRASS have such command?
> (In short, I want to know command which works like "d.what.rast"
> command but non-interactively.)
Use "r.what".
Glynn Clements <glynn.clements at virgin.net>
