[GRASSLIST:3075] Re:overlay site attributes on areas
Michele
michele.rocc at libero.it
Thu Apr 1 03:04:47 EST 2004
Dear David,
If you want to display polygon and points together simply run d.dm& (in grass50/53) at the command line and use the graphical interface do do that, yuo can display any type of map (raster, vector and site).
If you want to generate a single map, with:
s.to.vect (make a vector map from site)
v.patch (pach 2 or more vector map in one single map).
Michele.
> Wasn't there a command to do point in polygon (vector) overlays? I thought
> I remembered doing this, but I can't remember how.
> David Mahoney
> Llarix Solutions
> Box 967, 1215 9th Ave.
> Valemount, BC V0E 2Z0
> 250-566-4163x208 days
> mahoneyd at unbc.ca
