[GRASSLIST:3087] Re: New TclTk interface for GRASS 5
Jeff Hubbs
hbbs at comcast.net
Fri Apr 2 19:17:52 EST 2004
Dr. Barton -
Do you have any info on compatibility with GRASS 5.7?
- Jeff
On Thu, 2004-04-01 at 14:12, Michael Barton wrote:
> For the past couple months, I've been developing an update to the
> venerable TclTk menu system for GRASS 5. Besides reorganizing the menu
> hierarchy, I've added all the rest of the GRASS commands that are not
> in the standard menus (about 200 new ones in all) along with commands
> to produce fairly nice looking output from GRASS screens as graphic
> image files you can paste into other applications (in *.xwd, *.tiff [8
> bit color], and *.png formats).
> It has been tested pretty extensively and will soon go into the CVS
> for GRASS 5.3. It is designed for GRASS 5.3, but should work pretty
> well for GRASS 5.0.3 also (except where GRASS 5.3 modules have new
> options not available in GRASS 5.0.x). If you'd like to use it with
> your current GRASS installation, you can download the complete menus
> (as a *.tar.gz file) along with instructions for installing them at
> http://www.public.asu.edu/~cmbarton/grass.htm
> If you have any questions, let me know.
> Enjoy!
> Michael Barton
> <fontfamily><param>Helvetica</param>______________________________
> Michael Barton, Professor & Curator
> Department of Anthropology
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671</fontfamily>
