[GRASSLIST:3090] Re: segmentation fault with GDAL
stef
sepd2003 at yahoo.com
Sun Apr 4 12:13:54 EDT 2004
Hi Paul,
Thanks for your reply. I got the GDAL binaries from
the linked grass site for GDAL.
I did convert the jpg to a tiff via-a-vis Photoshop
and then read the file into grass. I get the
following:
>r.in.tiff complexCorridor
{all the flags etc}
then three maps get placed into /cell
complexCorridor.b
complexCorridor.g
complexCorridor.r
I then opened a monitor to read the raster map of
complex corridor in and I get this message: "raster
map not found in current mapset"
I then ran r.support -r and get the following "raster
Any other suggestions?
Thanks,
Stef
--- Paul Kelly <paul-grass at stjohnspoint.co.uk> wrote:
> On Sat, 3 Apr 2004, stef wrote:
> > Dear GrassList,
> > I am running linux binaries which include the GDAL
> > binaries and want to import a .jpg file. I keep
> > getting this segmentation fault-- I verified that
> > have enough memory on the system-- any other
> > suggestions?
> Your binaries are probably broken. Where did you get
> them? You will need
> to obtain working ones or compile yourself. Probably
> easier to do something
> like convert the JPEG into a TIFF using some other
> image processing
> software and then use r.in.tiff.
> Paul
__________________________________
Do you Yahoo!?
Yahoo! Small Business $15K Web Design Giveaway
http://promotions.yahoo.com/design_giveaway/
