[GRASSLIST:3123] Re: Problem with monitor....
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Fri Apr 9 05:50:04 EDT 2004
Ok thanks for the help, now i've compiled all the grass code on my
external drive and got no error.
Now i can run grass with:
#> /mnt/maxtor_linux/grass_home/grass53/bin/grass53
but still remain some problem.....
- Monitor problem:
I can run a monitor only if i am ROOT, otherwise i get the same old
error: ERROR: In main.c: Couldn't get socket path.
whoami gives the rigth answer;
/tmp/grass-<username> is a directory, exist and i'm the owner;
what am i missing? maybe mounting my external drive (where i put my bin)?
i use in fstab: /dev/sda5 /mnt/maxtor_linux ext2 defaults 1 2
- Library problem:
I cannot see libproj.so.0 because my LD_LIBRARY_PATH doesn't contain the
path /usr/local/lib.
if i run:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
everything goes fine.....
but it should be already contemplate in some grass variable, in fact i run:
CFLAGS="-O3 -march=pentium4 -Wall" LDFLAGS="-s" ./configure
--prefix=/mnt/maxtor_linux/grass_home/grass53
--with-bindir=/mnt/maxtor_linux/grass_home/
--with-postgres-includes=/usr/include/pgsql/server/ --with-motif
--with-motif-includes=/usr/X11R6/LessTif/Motif1.2/include/
--with-motif-libs=/usr/X11R6/LessTif/Motif1.2/lib/ --with-blas
--with-lapack --with-glw --with-dbm
--with-dbm-includes=/usr/include/gdbm --with-freetype
--with-freetype-includes=/usr/include/freetype2/ --without-readline
--with-fftw --with-proj --with-proj-libs=/usr/local/lib --with-cxx
Any helps to give me?
Thanks, and sorry for my limited linux knowledge
Glynn Clements wrote:
>>- when i call d.mon start=x0 i get this error message:
>> GRASS:~ > d.mon start=x0
>Possible reasons for this error are:
>1. It couldn't figure out your username (does the "whoami" program
>give the correct information)?
>2. It couldn't create the /tmp/grass-<username> directory.
>3. The /tmp/grass-<username> directory already exists, but you don't
>own it.
>4. /tmp/grass-<username> already exists, but it isn't a directory.
>> Failed to get socket name for monitor <x0>.
>> Problem selecting x0. Will try once more
>These are a direct consequence of the driver failing to start due to
>the above error.
Ing. Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata at supsi.ch
Internet: http://www.ist.supsi.ch
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040409/61decd50/attachment.html
