[GRASSLIST:3129] Re: can't display spanish DGN file
    Hamish
    hamish_nospam at yahoo.com
    Sat Apr 10 23:26:37 EDT 2004
> I have compiled v.in.dgn in 5.0.3 and used it to import a DGN file
> made by (Spain) CNIG
> Import seems to be succesful. I have now dig, dig_atts & dig_cats
> files. But d.vect displays nothing.
You might need to run v.support on the new vectors.
Try v.info, it's a good check that everything imported ok.
Set the region to the extent of the new vector file with
 'g.region vect=...'
If that still doesn't work, try labelling everything with v.llabel or
v.alabel. Unlabeled vectors sometimes don't display (mostly d.vect.line
and d.vect.area).
Hamish
