[GRASSLIST:3140] Re: blending seams in patch
Hamish
hamish_nospam at yahoo.com
Mon Apr 12 00:37:04 EDT 2004
> Perfect! Thank you. Simply running "r.neighbors in=patched_map
> out=fixed_up_map method=average size=5" looks to have cleaned
> everything up quite nicely.
Note the resultant "fixed_up_map" will be a smoothed version of the
original!
If you need to preserve detail, run:
r.patch in=patched_map,fixed_up_map out=patched_map2
so it only fills in averaged data when it finds a null gap.
Hamish
