[GRASSLIST:3159] Re: a problem in grass57
Markus Neteler
neteler at itc.it
Wed Apr 14 04:45:21 EDT 2004
On Tue, Apr 13, 2004 at 03:08:18PM +0300, temiz wrote:
> hello
> when I used firstly grass57. I encountered suh a problem in nviz:
> "couldn't execute nviz2.2_script"
> what can I do ?
At time you cannot start nviz in 5.7 with GUI, use it
from command line instead:
nviz -q
or
nviz elevation.dem ...
I would appreciate a hint why the GUI startup doesn't
work. For some reason the $GISBASE/etc/nviz2.2/scripts/nviz2.2_script
is not found. Is there a way to simplify the startup script?
Regards
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
