[GRASSLIST:3172] Re: advice on building a workstation PC for Grass
David Mahoney
mahoneyd at unbc.ca
Wed Apr 14 19:31:09 EDT 2004
For raster processing, faster disks seem to be as important as anything.
If possible, go with serial ATA drives, and if you can afford it, a RAID
setup. Gobs of RAM also helps, as extra goes to disk caching, which speeds
you up a lot. Perhaps someone who knows more about the specific computing
requirements of GRASS could give a little more direction concerning CPU
choice.
Dave
On Wed, 14 Apr 2004, Philipp Molzer wrote:
> Hi,
> I'd appreciate any advice on building a new PC, with running Grass in
> mind. I am currently using
> AMD Duron Processor
> cpu MHz : 1294.521
> RAM : 750 MB
> Linux 2.4.20-28.8
> The ram seems to be fine, but the CPU frequently max's out on things
> such as v.in.shape, r.patch, etc.
> I'd like to stay under $600 for motherboard, CPU, RAM, harddrive, and
> case. I know I am being quite vague about what sort of data I'm working
> with, but I'm sure that people must have opinions about what a dedicated
> Grass workstation would have in it.
> Thanks,
> Phil
Dave
