[GRASSLIST:3206] Re: bathymetry
Brent Wood
b.wood at niwa.co.nz
Sun Apr 18 16:28:02 EDT 2004
On Sun, 18 Apr 2004, Hamish wrote:
> > I am using GRASS 5.0.0 on a mac (10.2.8). I am not sure what you mean
> > by datum support.
> for a better explanation than I could give you, see:
> http://biology.usgs.gov/geotech/documents/datum.html
> > I thought that I specified the datum for a location
> > when I set it up. Do you mean that I can not project across datums
> > when using a command like r.proj?
> Not with GRASS 5.0.0, maybe there is limmited NAD27 and NAD83 support?
> Someone else would have to answer that, but generally no; you need a
> newer version of GRASS for r.proj to handle transformations between
> different datums correctly.
But you can export the data, & run it through the cs2cs program manually.
This is a part of the proj package (the same one GRASS uses to manage
reprojection).
>From the man page:
Cs2cs performs transformation between the source
and destination cartographic coordinate system
on a set of input points. The coordinate system
transformation can include translation between
projected and geographic coordinates as well as
the application of datum shifts.
After reprojecting it (with the datum shift) you can create a new GRASS
mapset for the new projection and import the data.
I don't believe you can overlay data from different mapsets on the fly
though.
Brent Wood
