[GRASSLIST:3230] Re: How to compile source code under win32
Fei Li
feili at telus.net
Tue Apr 20 10:59:59 EDT 2004
Thanks Richard,
I have installed whole cygwin package and passed some errors.
Now ./configure complain "configure: error: *** Unable to locate ODBC
library."
I went to the link unixODBC site and do not know what should I do.
I try to downloaded source code and run its configure.
The configure did not say any error but did not create makefile too.
What can I get ODBC for grass?
Thanks
----- Original Message -----
From: "Richard Greenwood" <rich at greenwoodmap.com>
To: "Fei Li" <feili at telus.net>
Cc: "GRASS Users Mailing List" <GRASSLIST at baylor.edu>
Sent: Monday, April 19, 2004 12:43 PM
Subject: [GRASSLIST:3219] Re: How to compile source code under win32
> Fei Li wrote:
> > Hi,
> > After install cygwin and grass souce code. I start cygwin from destop
icon.
> > I run ./configure without much error.
> > When I run make -f Makefile.in it failed by saying:
> > @SRCDIR@/src/CMD/generic/is64bit.sh: Can't open
> > .sh: No such file or directory
> > make: *** [pre-compile] Error 2
> > But I checked grass-5.0.3/src/CMD/generic/is64bit.sh is there.
> If configure is successful, you will get a Makefile. Makefile.in is just
> a seed file, not a Makefile for your system. If you have a Makefile,
> simply run 'make'. If you do not have a Makefile after running
> configure, then configure has failed and you need to add packages and/or
> modify configure options until configure is successful.
> R
> Richard Greenwood
> www.greenwoodmap.com
