[GRASSLIST:3238] Re: r.in.ascii floating point problem
Glynn Clements glynn.clements at virgin.net
Tue Apr 20 16:54:05 EDT 2004
Nivedita Candade wrote:
> r.in.ascii is not able to convert ASCII files containing floating point numbers
> (inspite of saying that FP values are imported).
Yes it is; you just have to use the -f switch.
> The 'cell' directory contains the raster file, but it is empty.
That is normal for floating point maps. The actual data is stored in
the "fcell" directory.
Glynn Clements <glynn.clements at virgin.net>
