[GRASSLIST:3247] Re: creating new mapset/location in batch-mode
Jan Hartmann
j.l.h.hartmann at uva.nl
Wed Apr 21 05:32:51 EDT 2004
Kinberger Michaela wrote:
> We are working on an internet application which uses grass for
> interpolation (idw).
> The user can select the kind of point data to send to grass. Now a
> shellscript will be executet to get
> back a .tif + .tfw viewd by the umn mapserver.
> what happens when two users start one grass location with the same
> mapset at the same time.
> is it possible to start idw two times with different mapsets but the
> same location and how can i create
> a new mapset/location in batchmode.
Normally, on a single system, GRASS can only be used by one user at the
same time. You can disable this by commenting out a few lines in
grass5/etc/Init.sh, but this is dangerous. The working mapset and region
are stored on disk, so the mapset of the second concurrent user will
become automatically that of the first one, and every change of region
will apply to all users. If both remain the same, it should be possible
to use GRASS simultaneously. I think that is the case with r.surf.idw.
I have been struggling with this problem in the same situation as you:
using GRASS as a backend for web-based MapServer applications. This hack
works for me, but it would be nice if GRASS could be really used in
parallel. I am not sure how difficult this would be to implement however.
BTW: MapServer can read GRASS datasets directly. This is slightly slower
than reading tiff files, but certainly faster than converting GRASS
datasets to tiff and using those. MapServer has to be compiled with Gdal
and Grasslib (not in the standard binaries).
Jan
dr.J. Hartmann
Department of Geography
University of Amsterdam
