[GRASSLIST:3253] RE: creating new mapset/location in batch-mode
Matt Doggett mdoggett at coas.oregonstate.edu
Wed Apr 21 12:02:30 EDT 2004
I've got an application that does exactly what you're doing. But what
I've done is created several 'working' Grass mapsets (apache1, apache2,
apache3, etc.). So when a user makes a particular request, my script
first checks for an available GRASS mapset (checks for a grass
lockfile). If apache1 is in use, it sends the request to apache2. If
apache2 is in use, it goes to apache3, etc. I have it setup to allow for
five simultaneous users which for us is more than adequate because the
mapset is only in use for a few seconds, enough time to do the grid
calculation and export the geotiff to Mapserver for rendering.  I use
geotiffs because the GDAL/Grass interface into Mapserver only allows
8-bit rasters and I have floating point grids with thousands of
categories.
-Matt
>-----Original Message-----
>From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
>Behalf Of Kinberger Michaela
>Sent: Wednesday, April 21, 2004 1:54 AM
>To: GRASS Mailing List
>Subject: [GRASSLIST:3246] creating new mapset/location in batch-mode
>Hi,
>We are working on an internet application which uses grass for
>interpolation (idw).
>The user can select the kind of point data to send to grass. Now a
>shellscript will be executet to get
>back a .tif +  .tfw  viewd  by  the  umn  mapserver.
>what happens when  two users start one grass location with the same
>mapset at the same time.
>is it possible to start idw two times with different mapsets but the
>same location and how can i create
>a new mapset/location in batchmode.
>thanks,
>michaela
>Institut fuer Geographie und Regionalforschung
>Universitaet Wien
>Kartografie und Geoinformation
>Departement of Geography and Regional Research
>University of Vienna
>Cartography and GIS
>Universitaetstr. 7, A-1010 Wien, AUSTRIA
>Tel: (+43 1) 4277 48646
>Fax: (+43 1) 4277 48649
>E-mail: kinb at atlas.gis.univie.ac.at
>WWW: http://www.gis.univie.ac.at/karto
