[GRASSLIST:3316] Re: Import with r.in.gdal
    Andrew
    selkiesdad at twcny.rr.com
    Fri Apr 30 10:59:05 EDT 2004
perhaps it (the library) isn't in the system library path... is
/usr/local/grass5/lib in your LD_LIBRARY_PATH (environment variable) or
/etc/ls.so.conf (or equivalent library loader configuration file)? Di
you install pre-compiled binaries that don't have gdal support? Did you
install the necessary support libraries  to use gdal (see the grass
installation documentation)?
Anja Drews wrote:
> Dear list,
> I am trying to import raster data with r.in.gdal in GRASS 5.0.3.
> I get the following error message:
> r.in.gdal: error while loading shared libraries: libpq.so.2: cannot
> open shared object file: No such file or directory
> In the directory /usr/local/grass5/lib I find the packages libpq.so.1
> and libpq.so.1.2.
> What package do I need to install to get libpq.so.2 ?
> Thanks for your help,
> Anja
