[GRASSLIST:3510] Re: How to correct SRTM data
Hamish
hamish_nospam at yahoo.com
Fri Apr 9 02:01:23 EDT 2004
> > I'm looking for ways to correct srtm data. I found that r.mapcalc
> > can correct mountain holes by interpolating GTOPO and SRTM data.
> > Can you gis gurus give me some pointer about correcting speckled
> > sea? And what about sea level and coastline?
> You can use the gtopo30 dataset to define your coastline. Everything
> that is null in gtopo30 can be made null in you SRTM dem using mapcalc
> r.mapcalc srtm2 = 'if(isnull(gtopo30),gtopo30,srtm1)'
> This gives a blocky coastline though (gtopo30 is ~900m resolution
> compared with~30 or ~90 for SRTM).
Not if you run 'r.buffer dist=900' on the gtopo30 map first.
Hamish
