[GRASSLIST:4083] Re: vectorizing rasters
Kirk R. Wythers
kwythers at umn.edu
Tue Aug 3 12:14:46 EDT 2004
On Aug 3, 2004, at 1:05 AM, Hamish wrote:
> v.trim was disabled apparently because it was buggy. If you compiled
> from
> source code, you can always compile the individual module with:
> cd src/mapdev/v.trim
> gmake53
> .. see
> http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass/src/mapdev/
> v.trim/BUGS
> instead try:
> [GRASS 5.3]
> v.rm.dangles
> [GRASS 5.7]
> v.clean tool=rmdangle thresh=
> or tool=chdangle + v.extract
> or tool=rmarea (or v.extract -d)
Thanks for the tip Hamish. I also found that r.neighbors with
method=mode and size=3, does a wonderful job of cleaning out artifact
cells. I think once I get v.rm.dangles fine tuned, I'll be in business.
> Hamish
Kirk R. Wythers
Dept. of Forest Resources
University of Minnesota
email: kwythers at umn.edu
tel: 612.625.2261
fax: 612.625.5212
