[GRASSLIST:4087] Re: GRASS5.03 vs GRASS5.7
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Tue Aug 3 03:33:17 EDT 2004
Just to chime in, on my mac running OS 10.3.4, my mail is sent to
/var/mail/my_user_name. I also get a message sent to my terminal
window whenever I have new mail. This is a new feature for me, but I
am not sure if it has to do with a change from OS 10.2 to 10.3 or from
OroborOSX to Apple's X11 or from grass 5.0.0 to 5.3/5.7 (I certainly
didn't conciously change anything else). Regardless, the mail function
now at least serves some purpose for me. Thanks to whomever.
-Ian
On Aug 2, 2004, at 11:13 PM, Glynn Clements wrote:
> Michael Barton wrote:
>> Thanks for the information on error messages. Some commands also
>> indicate
>> that they have completed their processing by sending an email (r.proj
>> for
>> example).
> r.proj doesn't do this. Are you thinking of photo.rectify (part of
> i.ortho.photo)? That sends mail upon completion. But then the imagery
> stuff never was particularly well integrated with the rest of GRASS.
>> I *think* (but am not sure) that this goes to sendmail. Since I
>> now have postfix internally--but only use it in some circumstances
>> for its
>> smtp server--I'm not sure where this ends up.
> photo.rectify and the libgis error-handling code both use the "mail"
> program to send notification messages; e.g. (from photo.rectify):
> mail = popen ("mail `whoami`","w");
> The mail will end up wherever the "mail" program (assuming that you
> have one) sends it, based upon the username returned by "whoami"
> (whoami returns the username from /etc/passwd corresponding to the
> effective UID).
> For a traditional Unix mail program, it will probably go to
> /usr/lib/sendmail or /usr/sbin/sendmail (which may or may not be the
> "actual" sendmail program; most MTAs include a program/script named
> "sendmail" for compatibility purposes).
> FWIW, this is essentially the same mechanism used by daemons which
> send email, e.g. crond.
> Needless to say, this is all somewhat Unix-specific. If you aren't
> using a "conventional" Unix system (e.g. you don't have a "mail"
> program or an appropriate entry in /etc/passwd), it may not work.
> Glynn Clements <glynn.clements at virgin.net>
