[GRASSLIST:4088] Re: Sharpening Lansat images
Ian MacMillan ian_macmillan at umail.ucsb.edu
Tue Aug 3 16:29:00 EDT 2004
The method that I have used with the most success is i.rgb.his, then
i.his.rgb.  The colors sometimes get a little screwy, but usually
playing with the resultant bands using d.histogram and r.rescale can
give you something useful.  An order of operations that I have used is
below to produce a fairly decent "true" color image with landsat.
combine bands 2 and 4 for more vivid greens and blues with
g.region rast=band2
r.mapcalc band2and4 = '(band2 + band4)/2'
i.rgb.his red_input=band3 green_input=band2and4 blue_input=band1
hue_output=hue saturation_output=sat intensity_output=int
g.region res=15
i.his.rgb hue_input=hue saturation_input=sat intensity_input=band8
red_output=red green_output=green blue_output=blue
r.colors color=grey map=red
r.colors color=grey map=green
r.colors color=grey map=blue
d.rgb r_map=red g_map=green b_map=blue
if things look a little off, use
d.erase blue
d.histogram red
then look at the curve and note where it drops off to zero on both
ends.  rescale your image with
r.rescale input=red output=red.rescale from=xx,xx to=0,255
repeat for blue and green
Good luck,
Ian
On Aug 3, 2004, at 11:55 AM, tatel at euskalnet.net wrote:
> Hi all,
> I've tried to sharpen some landsat images with HSV method to get a
> Hi-Res true color composite. Not really very successful. After
> sharpening, resultant colors are distorted (vegetation becomes blue)
> In http://esibert.is-a-geek.net/sig/cartes/landsat/multi/compose/ I
> have
> seen a sharpened true color composite with "good colors".
> This website references to
> http://www.cis.rit.edu/people/faculty/salvaggio/references/pdf/
> PERS1991v57n3p295-303.pdf)
> This pdf document speaks about an HPF (high pass filter) method which
> "distorted the spectral characteristics of the data the least" so I
> guess...
> a)This HPF method was used to make the good color composite
> b)This method seems to be the same as FF (filter fusion) method in
> http://wwwcs.uni-paderborn.de/cs/ag-kao/de/persons/kao/pdfPapers/
> osee.pdf
> where I've found this equation:
> HiResImg=i.ifft{LPF{i.fft(LowResImage)+HPF{i.fft(PanImg)}}
> However i.fft gives me a "ERROR: G_malloc: out of memory" message when
> usin region settings from low-res raster, and gives me a segmentation
> fault when using region settings from pan raster.
> Not using i.fft and i.ifft works but gives me very ugly results
> Questions are:
> 1) Is there really a sharpening method without color distortion?
> 2) Is this HPF method woeful?
> 3) What could I do?
> Thanks in advance
> Roman
