[GRASSLIST:4116] Re: Install grass57-5.7.0-2mdk.i586.rpm
Glynn Clements
glynn.clements at virgin.net
Fri Aug 6 06:33:12 EDT 2004
seikian at enciety.com wrote:
> Thanks to Glynn Clements for helping me.
> i still have a problem when installing "grass57-5.7.0-2mdk.i586.rpm"
> i have already install :
> fftw-2.1.5-4.1.fc2.fr.i386.rpm
> gdal-1.1.9-3mdk.i586.rpm
> gdal-python-1.1.9-3mdk.i586.rpm
> libgdal0-1.1.9-3mdk.i586.rpm
> libgrass5_0-1.0.0-1mdk.i586.rpm
> proj-4.4.8-1.i386.rpm
> All dependencies are already installed but why did i still find this error ?
> # rpm -ihv grass57-5.7.0-2mdk.i586.rpm
> error: Failed dependencies:
> libgdal.so.1 is needed by grass57-5.7.0-2mdk
I would have expected libgdal0-1.1.9-3mdk.i586.rpm to have provided
that. What does "rpm -q --provides libgdal0" say?
Where did you get the grass57 RPM? Was there any documentation
regarding which RPMs it requires?
> # whereis libgdal.so.1
> libgdal.so: /usr/local/lib/libgdal.so.1 /usr/local/lib/libgdal.so
That doesn't matter. As I mentioned before, anything which wasn't
installed by RPM doesn't exist as far as RPM is concerned.
Glynn Clements <glynn.clements at virgin.net>
