[GRASSLIST:4125] Re: converting vector files from 5.3 to 5.7
Stephan Holl sholl at gmx.net
Sat Aug 7 04:31:25 EDT 2004
Hello John,
On Sat, 7 Aug 2004 00:24:58 -0700 John <jwdougherty at mcihispeed.net>
wrote:
> I have searched through the mailing-list archives without luck.  Is
> there a command in GRASS 5.7 that can be used to convert GRASS 5.3
> vector files to the 5.7 format?  Even the name would be a help.
> Thanks,
> JWDougherty
Try v.convert to convert between vector versions.
GRASS 5.7.cvs:~ > v.convert --help
Description:
 Converts between GRASS vector versions.
Usage:
 v.convert input=name output=name [endian=name]
Parameters:
   input   input vector map
  output   Name of output vector
  endian   endian of input vector map
           options: big,little
           default: big
GRASS 5.7.cvs:~ >
Cheers
	Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040807/a605614b/attachment.bin
