[GRASSLIST:4165] Re: Map import cluelessness
H B
hamish_nospam at yahoo.com
Wed Aug 11 02:26:30 EDT 2004
> i.points.
> This command brings up an interface in your monitor where you select
> points to register. There are two ways to do this. First (using
> keyboard), you can click a point on your scanned map, then enter the
> coordinates of this point in the format of the projection you want.
> So for your case, you are going to enter in something like
> 25.78 45.80
> this is your latitude and longitude in your target location (NOT the
> xy coordinates that are given back to you on screen). You would
> typically get these points from lat-long that is on your scanned map,
> for example if you have a grid with degrees on your map.
Just a heads up: a week or two back I fixed i.points to accept lat/lon
input in the usual GRASS lat/lon format (ddd:mm:ss.sssH) as well as
decimal form.
Hamish
__________________________________
Do you Yahoo!?
Yahoo! Mail - 50x more storage than other providers!
http://promotions.yahoo.com/new_mail
