[GRASSLIST:4169] Re:
Markus Neteler neteler at itc.it
Wed Aug 11 05:35:04 EDT 2004
On Tue, Aug 10, 2004 at 01:39:48PM +0100, lawrence moran wrote:
> Hi,
> I'm using v.surf.rst in GRASS 53. I'm getting the following warning:
> taking too long to find points for interpolation--please change the
> region to area where your points are.
> My region is set correctly. Should I be doing something, perhaps wit the
> parameters, to speed up interpolation?
> Cheers,
> Lawrence
This message is a warning, no error.
However, you may verify with d.vect that you are working
in the desired (sub)region.
Markus
