[GRASSLIST:4201] Re: connect the dots
Gordon Keith
gordon.keith at csiro.au
Tue Aug 17 19:57:56 EDT 2004
On Wed, 18 Aug 2004 07:36, SWlab wrote:
> I have a series of LL coordinates, in a given order, that I imported in
> GRASS57. I'd like to connect one site to another, for example in the
> category order. What should I do ?
What I did (there may be a better method):
Export the sites as an ascii file,
reformat the file to the vector file format and
import the vector file.
The following script should more or less do the job:
# export the sites as an ascii file
v.out.ascii sitesname > sites.txt
# reformat the file to the vector file format
GISDBASE=`g.gisenv get=GISDBASE`
LOCATION_NAME=`g.gisenv get=LOCATION_NAME`
MAPSET=`g.gisenv get=MAPSET`
VECTFILE=$GISDBASE/$LOCATION_NAME/$MAPSET/dig_ascii/vfile.txt
echo VERTI: > $VECTFILE
echo L `cat sites.txt | wc -l ` >> $VECTFILE
awk -F \| '{ print " " $2 " " $1 }' sites.txt >> $VECTFILE
# import the vector file
v.in.ascii in=vfile.txt out=vectorname
This connects all the sites as a single line in the order they appear in the
sites file.
If you want more than one line you need to add a line consisting of L and the
number of points followed by the points to the end of the file. eg if
sites2.txt contains the second line add:
echo L `cat sites2.txt | wc -l ` >> $VECTFILE
awk -F \| '{ print " " $2 " " $1 }' sites2.txt >> $VECTFILE
You can obviously create the vfile.txt by hand, just remember it has to be in
the dig_ascii directory.
The man page for v.in.ascii should cover the details.
Hope this helps
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
The main thing is keep the main thing the main thing.
