[GRASSLIST:4240] RE: GRASS 5.7.0 (2004) - v.surf.rst strange behaviour
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Aug 24 11:03:58 EDT 2004
Hello Javier
On Tue, 24 Aug 2004, Javier A. Yebrin wrote:
> Thanks Paul,
> I have thought about using r.resamp.rst because it is the simplest solution
> to this problem,
> however I can't find this module in my Grass 5.7.0. installation. Do I have
> to compile it myself?
> Where can i find the source?
It is definitely in 5.7 as I remember Markus adding it, but perhaps it was
after the 5.7.0 release (you may need to upgrade to the CVS version). If
you have any other version of GRASS available it should be there. It is
compiled by default in 5.3.0.
Paul
